Offramp 2 vs. Offramp 3
0 Members and 1 Guest are viewing this topic. Read 2414 times.
timztunz
« on: 12 Jul 2010, 01:30 pm »
Sorry if this is a terribly simple question but I've not had much luck finding an answer elsewhere.  Can someone please tell me the main differences between and Offramp 2 and an Offramp 3?  Thanks for your help.
jtwrace
    • TIPP YouTube Channel
Re: Offramp 2 vs. Offramp 3
« Reply #1 on: 12 Jul 2010, 01:33 pm »
The "3" is the newer version.   :lol:
BobMajor
« Reply #2 on: 12 Jul 2010, 02:33 pm »
I have owned both of the Offramps. My first Offramp was the original not updated and I used it until about 6 months ago. I was very happy with it. My new Offramp 3 with Ultraclock was a huge step up in terms of soundstage realism.
Physically, the two aren't similar at all (the 3 is 3 times the size). I think Steve completely changed the power handling.
audioengr
« Reply #3 on: 12 Jul 2010, 06:14 pm »
That's correct.  The power supplies are upgraded, the internal clock cabling is upgraded and there is another reclocking stage in the Of-Ramp 3.  It also has I2S, S/PDIF and AES outputs.  Unlike the Turbo 2, it can also accomodate an Ultraclock.
Steve N.
timztunz
« Reply #4 on: 12 Jul 2010, 06:27 pm »
Thanks everyone.
