Multiamp problem
0 Members and 1 Guest are viewing this topic. Read 2412 times.
giannettino
Multiamp problem
« on: 10 Jul 2010, 05:10 pm »
Ok..i was really happy with my ref 9 SE v3.1...but..i'm moved to multiamp..so i've placed the amps on the ribbon tweeter..the one it's Ok..the second only "hisssssssssssssssssssssssssssssssssssss ssssssssssssssssssssss"..tested with a fullrange speaker..again ok..On the high route.."hisssss". The problem is solved with amp rolling..but..I want to use my Nufoce!!! :duh:
Ideas)
Sorry, as usual, for my poor english.. :oops:
Cheers
Aether Audio
    • http://www.aetheraudio.com
Re: Multiamp problem
« Reply #1 on: 13 Jul 2010, 01:06 am »
giannettino
Please e-mail me at [email protected] and I will try to help you fix this issue.  If one amp does not exhibit the problem while the other one does, we may need to take a look at it back at the factory.
Take care,  :D
-Bob
giannettino
« Reply #2 on: 13 Jul 2010, 01:59 pm »
giannettino
Take care,  :D
-Bob
THX Bob..you've mail.. :) :D
