0 Members and 1 Guest are viewing this topic. Read 4009 times.
they concluded not to have any panel area larger than 6" without bracing
Rythmik seem to think internal bracing is best done along the length of the cabinet rather than across it. Here's their 12" plan:http://www.rythmikaudio.com/download/DS1200s_sub_plan.pdfThe 15" driver plan is slightly different though probably helpful.
I would also, never, ever use MDF.
ps agree with planet 7 on making things slightly off centre.
What's the best material? Baltic Birch plywood? Bamboo plywood (Cali Bamboo, Plyboo)?
One should divide panels such that the aspect ratio of the subpanels is greater than the panel being braced.The subpanels should not have the same aspect ratio (ie the centre of a panel is not a good place to put a brace.The Rythmk looks almost like something i would design, except that i'd have the bracing just off centre (brace edge on centre line)It is unclear whether John's unbraced panel is 12x24 (actually 24 3/4 assumming 3/4" material) or 16x24. Assumming the first, i'd end up with subpanels 6x24.75 and 5.25x24.75. I would also, never, ever use MDF.dave
That said, with such long wavelengths, I bet it matters very little in the end...To see how bracing affects vibrational models, you might have a look at these photos of Chladni patterns:http://www.phys.unsw.edu.au/music/guitar/patterns.htmlAnd I'd bet that guitar builders are even crazier than loudspeaker builders
I believe that the box should be as inert as we can make it, I use 3 different substrates with dissimilar resonances glued with a rubber floor tile glue, a finished thickness of 48mm, with internal bracing. Wrapping another layer on a box is not that hard.
Actually I'm going to try an experiment in light-but-stiff.
Why no MDF? I think every speaker/sub I've ever owned has been MDF.
