WTB: Audiophile-rated USB Cable 10m or 30ft
0 Members and 1 Guest are viewing this topic. Read 3391 times.
earlgrey
« on: 8 Jul 2010, 12:36 pm »
Any dealer or seller with the above mentioned to sell pls pm me, new or used acceptable. You will need to ship the item to Singapore and I will pay for the shipping. Payment will be done by Paypal.
Niteshade
    • Niteshade Audio
Re: WTB: Audiophile-rated USB Cable 10m or 30ft
« Reply #1 on: 8 Jul 2010, 01:02 pm »
I don't believe you will find a USB cable that is 10m long. Approximately 4 meters is the longest recommended cable. It sounds like you may want to get into networking to try and solve the problem or just move the two devices closer together.
cryoparts
« Reply #2 on: 9 Jul 2010, 01:45 am »
5M is the longest allowed by the spec.
Check into an Opticis system.
Peace,
Lee
WGH
« Reply #3 on: 9 Jul 2010, 02:16 am »
I have successfully used a 5M active extension to make a 10M run. I have changed my wiring so the HagUSB is in the middle between a 5M USB and 5M Blue Jean Cable SPDIF cable but I never heard a difference between the two configurations.
Monoprice has the extension cable I used.
http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10303&cs_id=1030304&p_id=2779&seq=1&format=2
Wayne
srb
« Reply #4 on: 9 Jul 2010, 03:25 am »
I have successfully used a 5M active extension to make a 10M run.  Monoprice has the extension cable I used.
Although I'm not a big proponent of "audiophile-rated" USB cables, I can't really see the logic of using one in conjunction with a generic active extension cable.
WGH
« Reply #5 on: 9 Jul 2010, 03:32 am »
I think the standard (non-active) 5M USB cable was from monoprice too.
Wayne
srb
« Reply #6 on: 9 Jul 2010, 04:16 am »
I'm with you.  I just meant that for the OP, using the Monoprice active extension with an "audiophile" USB cable would seem to negate any "advantages" of the high-priced cable.
« Last Edit: 9 Jul 2010, 06:30 am by srb »
