Pure Vinyl #@%&!!
0 Members and 1 Guest are viewing this topic. Read 1651 times.
ZLS
Pure Vinyl #@%&!!
« on: 8 Jul 2010, 05:38 am »
 :duh:  I will not talk about my apparent inability to install the latest version of Pure Vinyl.
    I refuse to speak about if I only had the patience to wait, I could of purchased Pure Music(which is all that I use it for) for a fraction of the price.
    What I will ask for help concerns why I cannot get my Imac to play through my speakers when I enable Pure Vinyl.  Itunes yes; Front Row yes, even Plex (don't ask) yes.
    Not Pure Vinyl though.  It plays through my internal speakers even though I my DAC shows as being connected; likewise with my Imac in preferences.
    Any suggestions would be greatly appreciated.
    The real bite is that i really like the sound of the Pure Vinyl; I prefer it over Front Row which was my previous standard.
    I thank you gentlemen in advance.
low.pfile
Re: Pure Vinyl #@%&!!
« Reply #1 on: 8 Jul 2010, 06:01 am »
Are you selecting your DAC output in the Audio Midi Setup?
srb
« Reply #2 on: 8 Jul 2010, 06:32 am »
He says his other applications play through the DAC [iTunes, Front Row, Plex (don't ask)], but not Pure Vinyl.  Is there a preference or setup within Pure Vinyl where the audio output device also needs to be selected?
jaywills
« Reply #3 on: 8 Jul 2010, 11:42 am »
"Is there a preference or setup within Pure Vinyl where the audio output device also needs to be selected?"
Yes.  Pure Vinyl>Preferences>Advanced Audio Setup>Select output device.  Good luck.  Cordially,
bunnyma357
« Reply #4 on: 8 Jul 2010, 12:15 pm »
If you want a simpler set-up, I believe that the Pure Vinyl license allows you to also download and run Pure Music using the same activation code, so you could try that.
For Pure Vinyl, I'd check that all of the following are set to using the DAC and that they are set to a sampling rate that the DAC can handle.
1) Check if there is a configuration program for your DAC, could be a stand alone application or a preferences pane in System Preferences
2) System Preferences  >  Sound  >  Output
3) Applications  >  Utilities  >  Audio MIDI Setup
4) Pure Vinyl  >  Preferences  >  Multichannel  > Setup  (Make Sure Bus 1 is set up to output properly)
5) Pure Vinyl  >  Preferences  >  Advanced Audio Setup  > Device Selection  >  (Set this up so either you select outside of PV or from the application - if set to within PV make sure that it is set to the DAC, may need to relaunch the program to take effect)
One other obvious thing is just to ensure that Mute or Dim aren't selected in the PV interface and the volume sliders aren't at zero.  If the input is set to the internal Mic, PV will mute the output and set the volume to zero, to avoid feedback, so you may have to adjust it back to a level where you can hear something.  You can defeat PV from taking this protective action in the preferences if it bugs you.
Jim C
