Other Stuff
Archived Manufacturer Circles
Herbie's Audio Lab
UltraSonic Binding Post Washers
0 Members and 1 Guest are viewing this topic. Read 2491 times.
sac8d4
6 Jul 2010, 05:00 pm »
Heye Steve,
Can you tell me if the larger of the 2 Binding Post Washers sizes will fit a 3/8 binding post?
Herbie
Industry Contributor
Re: UltraSonic Binding Post Washers
7 Jul 2010, 01:38 pm »
Yes. Large binding post washers have just enough flex to them to accomodate a 3/8" post. It's a tight fit, though. (If you order them online, mention in the "comments" section of the order form that they are for 3/8" posts and I'll fudge the inside diameter a little bigger for you.)
Herbie's Audio Lab
Last Edit: 23 Aug 2010, 12:57 am by Herbie
Other Stuff
Herbie's Audio Lab
