El34 Stereo Tube Amp Singled-Ended triode / ultra-linear
0 Members and 1 Guest are viewing this topic. Read 4164 times.
waamamps
    • WaamampS
Amazing Warm Sound - 100% hand built
Beautiful, 100% hand built stereo, singled-ended class A Triode/Ultra-Linear, all tube power amplifier using EL34, 6N1P and 5U4 tubes. This amplifier layout has been carefully designed using a combination of Vintage, and high quality components. These high quality components are brand new and consist of Triad filter choke, Heyboer output transformers, Illinois electrolytic capacitors, poly capacitors, carbon resistors, gold-plated RCA jacks, speaker jacks, top grade ceramic tube sockets, IEC connector and power switch. Coupling capacitors are poly coupling caps. Illinois electrolytic capacitors are used in the cathode section and Cornell-Dubilier electrolytic capacitors are used in the power supply section. Vintage Marantz dual stereo volume control was used and in the input stage, gold plated shielded wire was used. All components are perfectly matched left to right for proper channel balance. This amplifier was designed on a garolite board, with all handwired, point to point circuitry using less wire to prevent hum and all grounds are in the correct places. This design allows this amp to run continuously, with extreme quiet operation. This amplifier has built in volume control and can be used with or without a preamp. You can connect any fixed or variable source output directly to this amplifier. You can use the audio out from an iPod, CD, DVD, MP3, Computer, TV, XM or SIRUS to the input connection. Amplifier was designed utilizing four tubes, one 6N1P (Input) can be substituted with 6922, 6FQ7, 6EV7, 6GU7, 6BQ7, 6CG7 or 6DJ8, two Bugera EL34 (Output) and 1-5U4 (Rectifier) can be substituted with 5Y3,GR34 or 5AR4. This amplifier features switchable Triode/Ultra-Linear mode, two pair of inputs (front/rear), volume control, power switch, power indicator, right/left speaker terminals (8 Ohms) and circuit protection. You will be amazed at the bass sound of such a small amplifier. Amp works great into any 4 and 8 ohms speakers.
Specifications:
* Input connector - Two pair of inputs (switchable, Front/Rear).
* Built in volume control and can be used with or without a preamp.
* Tubes: 2-EL34 (Bugera), 1-6N1P (Russian type) and 1-5U4 (GE)
* Input Impedance: 100K ohms
* Load Impedance: 8 Ohms
* Circuit Type: Single-Ended Class A
*All tube signal path, no feedback, switchable between triode and ultra-linear operation.
* Power Output: 8 Watts x2
Included:
* Power Stereo Tube EL34 Amplifier AC, 115 Volts
* Dimensions: W 13 1/2" x D 11 1/2" x H 2 1/2"
* IEC power cord
More pictures are available upon request.
Any questions please email me at: [email protected]
Asking: $950
Gopher
Re: El34 Stereo Tube Amp Singled-Ended triode / ultra-linear
« Reply #1 on: 8 Jul 2010, 12:41 am »
I just visited your website and have to say: You make some very attractive pieces!
Any reviews up?
Good luck!
