power voltage?
0 Members and 1 Guest are viewing this topic. Read 2411 times.
ricardojoa
power voltage?
« on: 3 Jul 2010, 06:50 pm »
Anyone know what is the power input voltage for CIA electronics. My country has 220v, can i use CIA products? thanks
CIAudio
Re: power voltage?
« Reply #1 on: 3 Jul 2010, 09:54 pm »
Our amplifiers are offered in 3 voltage ranges:
100V
110-120V
220-240V
DAC, HP Amp, PLC-1 come with 115-120 AC adapter. To use with 220-240V, VAC-1 is required.
VPC-3 is fully passive and requires no power supply.
seaninbrisbane
Re: power voltage?
« Reply #2 on: 20 Mar 2011, 12:15 pm »
I'm looking to buy a used VAC-1 PSU.  Don't seem to be many for the Australian voltage - are they easy to convert from US voltage?  Thanks~
CIAudio
Re: power voltage?
« Reply #3 on: 20 Mar 2011, 02:43 pm »
Input voltage is set by solder-in jumpers on the pcb and is not user-selectable.
