Selah Audio Aquamarine 12" subwoofer - $775
0 Members and 1 Guest are viewing this topic. Read 2392 times.
JM
« on: 2 Jul 2010, 09:33 pm »
I'm the first owner of this 12" sub. It was built to order by Rick Craig (owner and designer of Selah Audio). It gives a very solid, tuneful bass. A great sonic foundation. I've had this sub for about 3 years now and have mate it with all kinds of speakers. It is very easy to integrate with the main speakers, it's the kind of sub that just disappears, that doesn't call attention for itself, only when the program calls for it. It goes down to 20Hz easily. The built in EQ allows it to adapt to any room.
It is a sealed 16"x16"x16" box finished in natural Cherry with a massive 12" drive, a Sonicraft SC12NRT featuring the Aurasound motor design. The amp is class-D using high-end UcD technology capable of delivering 400W into 4 ohms. It provides 3 options for connecting to an audio or A/V system: stereo line input from a pre-amp (stereo RCA), 5.1 or 7.1 (X.1) input from an A/V processor or receiver (mono RCA), or high level input from an amp or integrated amp speaker outputs (binding-posts).
Included are spikes and protective disks for the floor when not used over carpet.
There are a few minor scratches on the enclosure, nothing major, just regular usage. And some discoloration around the driver, this is only visible if the grill is removed (see pictures).
The only reason I'm selling is because I recently got new speakers that go very low and the sub is now superfluous.
Asking: $775
« Last Edit: 25 Sep 2010, 01:07 am by JM »
JM
Re: Selah Audio Aquamarine 12" subwoofer - $650
« Reply #1 on: 10 Aug 2010, 11:30 pm »
JM
Re: Selah Audio Aquamarine 12" subwoofer - $775
« Reply #2 on: 25 Sep 2010, 01:07 am »
bump
