0 Members and 1 Guest are viewing this topic. Read 4344 times.
If you put:"Measuring Input and Output Impedance" into a search engine, you will come up with pages like the one below:www.sengpielaudio.com/calculator-InputOutputImpedance.htmBasically what you do is input a test tone through a variable resistor while measuring the output voltage. When the output voltage is reduced to 1/2 of the no resistor value, the adjusted resistors value is equal to the input resistance.
Never mind... that's way more than I bargained for. Since I don't have a pay grade, it's more than that, too! Thanks anyway!
