tube replacement
0 Members and 1 Guest are viewing this topic. Read 1331 times.
Derockster
tube replacement
« on: 29 Jun 2010, 12:32 am »
Hi guys,is the 5y3 a direct replacement for the 5ar4/gz34 tube?Thanks in advance Derockster
ltr317
Re: tube replacement
« Reply #1 on: 29 Jun 2010, 02:53 am »
It depends on the circuit of your amp.  Both rectifiers have the same pin out and are full wave, but operating parameters are different.  For instance, the 5AR4 has a plate resistance of around 80 ohms, while the 5Y3 has resistance of 400-450 ohms I believe.  So if you have a fairly high current amp, the 5Y3 will have a much greater drop in voltage during loud passages, thereby a reduction in power.  The amp may not sound as good as distortion will increase.  You should contact the manufacturer to determine if the circuit allows for that.
Listens2tubes
« Reply #2 on: 30 Jun 2010, 02:18 am »
Here are the 2 sites I use for tube info
http://www.nj7p.org/Tube4.php?tube=5Y3
http://tdsl.duncanamps.com/show.php?des=5Y3
Neither show a 5AR4 as sustitute for a 5Y4 or vice versa.
Derockster
« Reply #3 on: 30 Jun 2010, 02:58 am »
Thanks guys. :D
