Audio/Video Gear and Systems
Owner's Circles
Bent Audio Owners
John Chapman
Seiden Model 32SG 1-2-6 in stereo version?
0 Members and 1 Guest are viewing this topic. Read 1628 times.
raygun
17 Feb 2004, 07:55 am »
Hi guys, I presume the Seiden Model 32SG 1-2-6 source selector switch on Bentaudio is a single channel, mono switch.
Is there a stereo version (2 deck?)? So I can just use 1 switch for both channel duties?
Thks for any reply.
raygun
John Chapman
Facilitator
17 Feb 2004, 12:58 pm »
Hello!
This another one of those 'if' answers! When i use the switch in the NOH pre-amp I use one per side for dual mono source select. It keeps the signal path flow in the chassis the way I want it.
The switch I use is a one deck '2 pole' switch. When using it to switch ballanced inputs and/or to switch both hot and ground on the rca signals then you need 2 switches.
If (here is the if!) you just have rca inputs and you just switch the hot's (traditional way of doing it and the way most pre-amps do it) then one of these switches will switch inputs for 2 chanels.
Many Thansk!
John Chapman
www.bentaudio.com
Owner's Circles
Bent Audio Owners
John Chapman
