Acoustic Research AR-XA: Worth refurbishing?
0 Members and 1 Guest are viewing this topic. Read 1868 times.
Niteshade
    • Niteshade Audio
« on: 28 Jun 2010, 11:56 am »
What do you think of the AR-XA turntable? It has a Shure cartridge, yet is missing the tone arm counterweight. It may need a belt. The price is $70.00. I was told it does play.
Wayner
Re: Acoustic Research AR-XA: Worth refurbishing?
« Reply #1 on: 28 Jun 2010, 03:45 pm »
Having owned 5 of these tables at one time or another, I will cut right to the chase. The motors on these tables are weak and even if you find one on ebay or other places, they have a hugh percentage of being of poor strength. Tonearm counter weights can be had, but the motor is a problem.
I will not recommend this table to anyone anymore beccause of the motor problem and there isn't a replacement. You can buy one from Hurst #3021-001, but it's high torque is going to send vibrations thru the plinth and the table will be too noisy.
My advice is to look else where.
Wayner
Niteshade
    • Niteshade Audio
« Reply #2 on: 29 Jun 2010, 12:31 am »
Thank you for the advice. It was tempting!
I guess not too many people have those on here.
orthobiz
« Reply #3 on: 1 Jul 2010, 02:06 am »
You can contact vinylnirvana.com for info. He's an AR nut (in a nice way)
Paul
