Harmony One Remote and BP-6
0 Members and 1 Guest are viewing this topic. Read 1066 times.
mariusconst
« on: 27 Jun 2010, 10:24 pm »
Hi James,
I have just bought a 2BSST and a BP-6 and I am trying to configure my Harmony One remote to control the Volume Up/Down and Mute.
I programmed the Harmony but BP-6 does not seem to understand the remote signals.
Are the BP-6 codes passed to Logitech correct as in the Harmony remote the commands are now from Logitech database and obviously I do not have the original remote to overwrite the database setting by learning the infrared command from the original remote.
I am not sure if it helps but can I use my SP1.7 remote to learn the Harmony remote?  I did not suceed to use the SP1.7 remote with the BP-6 but maybe there are some setting I need to use before using it...
Marius
