It's getting ugly
0 Members and 1 Guest are viewing this topic. Read 6409 times.
Moon Doggy
Re: It's getting ugly
« Reply #20 on: 29 Jun 2010, 04:12 am »
Absolutely no complaints with the Clearaudio/Benz combo. Be sure to keep enough money aside for a great cart like the Benz ACE 'cause the cart is 1/2 the system IMO :) Add on tweaks like the suspension and a $250 record clamp for major sound improvements.
vegasdave
« Reply #21 on: 29 Jun 2010, 04:21 am »
Ok, I was shooting for the Performance SE 'table with the carbon fiber tonearm. Then slapping a Maestro cartridge on it. Unfortunately in North America the distributor is not including the catridge like Clearaudio specifies.
http://www.clearaudio.de/eng/lw_performance_se.html
I only have MM in my BP6 preamp. As far as clamps, I like the Twister clamp for $100.
Moon Doggy
« Reply #22 on: 29 Jun 2010, 04:29 am »
Ok, I was shooting for the Performance SE 'table with the carbon fiber tonearm. The slapping a Maestro cartridge on it. I only have MM in my preamp. As far as clamps, I like the Twister clamp for $100.
Sounds great!  :thumb: The HRS clamp comes highly recommended as well. All the Clearaudio accessories are extremely expensive :o but very cool to add on to the TT 8) Like the Emotion isolation feet 3 for $200
vegasdave
« Reply #23 on: 29 Jun 2010, 04:35 am »
Thanks. Ok, does that flatten the record like the Twister clamp? Yeah, they are. Kind of silly, but I suppose they're worth it. I just want the clamp anyway.
Moon Doggy
« Reply #24 on: 29 Jun 2010, 04:40 am »
It both flattens and absorbs the vibrations. The bass becomes much tighter and faster with a great clamp /isolation feet combo
vegasdave
« Reply #25 on: 29 Jun 2010, 05:40 am »
Ok, cool. Thanks.
