0 Members and 1 Guest are viewing this topic. Read 22243 times.
bigwbwb,Cool or should I say really warm!! So how does it sound to you vs the stock Logitech Supply.I spent a good amount of time listening to the Jerome supply vs the Original Logitech Supply this weekend.Its a pain to restart and rescan all my flacs in the external powered SSD drive to make quick on the fly A-B comparisons, I am working on a switch that will allow me to do this in the near future.Alex
Absolutely right, Bob.It is an old school design with a goodly sized transformer and op-amp regulated circuit driving discrete transistors mounted on a large heatsink. Nice BIG smoothing capacitors. The output cap could be a bit larger.It is definitely quite a step up from the PE supply. I also like that you can use whatever AC cable you want. It does require you to cut off the DC connector and install the proper sized plug to fit the Touch.
Which power supply are you referring to?The best way is to measure it. Use your DVM. If you don't have one, buy one. Harbor Freight sells them for under $10.00 and you can find multiple uses for one.If you mean the Jerome supply, I believe the brown wire is 5 volt positive and the black is ground. Measure to make sure.
Most transformers will hum. It all depends on how loud the level is. These are all surplus power supplies. There may be some of them that are aged to the point that the coils in the transformer are vibrating. If the hum is too loud from your listening position, contact the vendor to see if they would be willing to exchange the power supply.
Will this work for TOUCH? Seller advertises it for SB3. It is 5V 2A while TOUCH needs 5V 3A. But then again Jerome unit is 2A too. http://cgi.ebay.com/Logitech-Squeezebox-3-SB3-Upgraded-Power-Supply-/300509139644?pt=LH_DefaultDomain_0&hash=item45f7bd92bc#ht_1130wt_905I'm very interested in it since it has R core transformer.
