0 Members and 1 Guest are viewing this topic. Read 22244 times.
Hi Vlad,I have not swapped the original switching supply back in, but I'll try to do that in the near future.If any of you are considering experimenting with a linear supply for the Touch (or SB3), the Jerome supply that Wayne links to above is a great deal. I bought one out of curiosity and I was stunned at how nice it was for $10. I've attached a pic of the guts.Bob
Absolutely right, Bob.It is an old school design with a goodly sized transformer and op-amp regulated circuit driving discrete transistors mounted on a large heatsink. Nice BIG smoothing capacitors. The output cap could be a bit larger.It is definitely quite a step up from the PE supply. I also like that you can use whatever AC cable you want. It does require you to cut off the DC connector and install the proper sized plug to fit the Touch.
It will work with both the Touch, if you don't use a buss powered USB HD, and the SB3/Classic, if you change the DC connector. It will not work with the DUET Receiver.
Between the BOLDER Modded Elpac WM-220 and the BOLDER Modded Jerome Industries, the BOLDER Modded ELPAC would be the better sounding. It is completely rebuilt only leaving the transformer and regulator alone.The best buy for the money would be the stock Jerome Industries.
