Tube Preamp Suggestions to warm up Bel Canto Monoblocks
0 Members and 1 Guest are viewing this topic. Read 2314 times.
pwhinson
I have a home theater setup with Thiels all the way around (powerpoints as the surrounds; 2.4 as LR, and SCS4 as center) along with a B&K Ref 50 - rather long in the tooth - and Bel Canto monoblocks.
The B&K has what they're calling a "stereo direct" or passive linestage mode which I've been using for regular stereo listening.  Still I can't help but think that the B&K is doing SOMETHING to the signal because I hear a midrange suckout in the presence region which, when I put my brother's uber-expensive totally out of my league Aesthetix Calypso in - and it resolves the recessed midrange and provide mucho magic.  So I'm looking for a tube amp that will drive the Bel Canto digital amps.  I'm told the tube preamp needs to have a lowish output impedence.  I don't was mushy-squishy euphonic tubes but I do was perhaps a slightly forward midrange.  Any suggestions?  Rogue Audio? Old ARC? Old CJ?  Audible Illusions? Cary? (generally too expensive even used as near as I can tell), BAT?
Old anything I can buy used cheap?  Help me develop a shortlist.  All advice/suggestions welcome!
invstbiker
Re: Tube Preamp Suggestions to warm up Bel Canto Monoblocks
« Reply #1 on: 25 Jun 2010, 05:05 am »
pwhinson,
I have Bel Canto monoblocks MKll's and a LAMM 2.1 deluxe with NOS tubes. Sounds wonderful
rlee8394
« Reply #2 on: 25 Jun 2010, 05:12 am »
This would work.
http://www.avahifi.com/index.php?option=com_content&view=article&id=143&Itemid=220
Check out their new tube preamps as well.
Ron
pwhinson
« Reply #3 on: 26 Jun 2010, 05:28 pm »
Thanks for the suggestions.  The Van Alstine rebuild of the dynaco looks very interesting although I would have to have them build one because I'm just not savvy with a soldering iron.  I ran across a great deal on a used Rogue 99 magnum which I'm trying to buy (still negotiating).  I couldn't find the output impedance on the val alstine website - that's an important number in matching a tube preamp to the bel canto digital amps.  The lower that value the better.
mca
« Reply #4 on: 26 Jun 2010, 06:31 pm »
I have heard that the Rogue is a very "non tubey" sounding preamp. YMMV.
Will2
« Reply #5 on: 26 Jun 2010, 06:46 pm »
Here are two direct suppliers with some great products for you to consider:
http://doddaudio.com/BatteryPoweredTubeBufferPreamp.aspx
http://www.bellaextreme.com/specials.htm
I'm not sure if you need gain or not - if so the Dodd buffer would be out - but the Dodd pre would work.
I've heard both and they sound great to me, but what do I know.  If you are at all interested in either I'd encourage you to call them directly and see what they have that might meet your needs.
Cheers
Will
ebag4
« Reply #6 on: 26 Jun 2010, 07:03 pm »
x2 for the Dodd! :thumb: :thumb:
I am running the buffer in front of a didgital amp and it sounds fantastic to my ears.
Best,
Ed
pwhinson
« Reply #7 on: 26 Jun 2010, 08:45 pm »
Thanks for the suggestions.  I had looked at the Dodd stuff but I'm pretty limited in terms of funds so I generally buy used and I think the Rogue will be fun to play around with.  From what I've read the Rogue is definitely not bloated or ill-defined on the lows or rolled off on the highs but does in fact have a bit of a forward midrange.  Depending on the tubes you can make it very tubey indeed but I want ARC at the extremes but a little bit more magic in mids than ARC.
