0 Members and 1 Guest are viewing this topic. Read 10945 times.
Sounds like your business is RAAlly growing. Although I am only two channel with RAAL right now, I'll be curious to see how the center channels come out. Chuck
Rick,Do you sell RAAL tweeters only to customers like myself? If yes what are the prices for a pair?
Both are 3-way designs with dual 4" or 5" woofers. Also in the works is a center that's the same size as the Sardonyx but using the Scan-Speak Illuminator woofers, Morel dome mid, and RAAL 70-10D.
If not, there are other sources to purchase...
Could I send my Sardonyx, Tanzanite and S6's in for a Raal tweeter upgrade?
Madisound sells them. But I believe that one of the RAAL tweeters that Rick uses (the 70-20XR in my Grandeur) is OEM only so you cannot buy that one. http://www.madisound.com/manufacturers/raal/index.php
line array with RAAL ribbons coming soon.
More details please. What driver? How many per side?
140-15D, eight per side. And I promise you can come listen to this one.
OK. With what other driver? Look forward to it.
To be announced later...
Rick, have you looked at Accuton's new C158-8-085 6" driver? It looks like it could be spectacular in an array set up. Very expensive, but I suspect an Accuton-RAAL line array would be truly "over the top"! We look forward to seeing your new model!
