0 Members and 1 Guest are viewing this topic. Read 9003 times.
CacophonnyI am going to give you some real good advice and i hope you take it into consideration. To get started you want to develop your own tastes. Make them your own, its good to get help but really the end result should be a very personal development of your own taste. This question trumpets your lack of personal involvement with your own gear. To answer your question, try them both on and off. What ever you like better go with.....
While we're on the subject of scientific basis for decisions ...What kind of effect do the grills have on the Songtowers? Has anybody done a frequency response comparison?I feel more comfortable leaving these beauties protected most of the time but if going grill-less makes a noticeable difference I'll have to reconsider.
I have tons of "personal involvement" with my gear. I listen to music every night.But I'm also relatively new to this, and thus don't always know what to listen for. I also don't trust my auditory memory unless it's a very obvious and significant difference (and based on what I've read neither should you). Different speakers make this type of significant difference that's immediately obvious to me. Nothing else I've heard (amps, source, cables) has made any difference at all as far as I can tell.
List your gear and maybe i can help...... What source are you using?, what amp,etc. You should be hearing differences.
Hi I took some measurements once and posted them, but good luck finding them. I'll try and measure again tonight. It makes an obvious difference in the plots, but I'm not claiming that difference would translate into an audible difference that would survive an A-B test. But at least I can document that it does change the frequency response.
So you don't want to list your gear....? No one is going to flame you over gear.
Do you run your Sacd into the integrated by analogue or digital connect? Try using a digital connect.
The amp only has analog inputs, so nothing I can try there...
Looking at the A-9555 it does not have any digital inputs.Bill
