"Quantum Destroyer" subwoofer - rythmik servo
0 Members and 1 Guest are viewing this topic. Read 1729 times.
Angaria
« on: 20 Jun 2010, 09:58 am »
So dubbed by a member here to auditioned it.  I was fooling around with constrained layer damping and this is one of the results.
It's two extra-thick sonotubes in a constrained layer setup, with integrated caps of 6-8 inches of alternating MDF and baltic birch plywood. (Tapered around woofer to allow for airflow). Lined with fiberglass insulation. Separate amp enclosure on back. Woofer and amp are the rythmic servo 350 watt and DS12 woofer (gray, downfiring). Currently several coats of primer on it. I could finish this in some exotic veneer if you want, or you could just stow it out of the way somewhere.
It
sounds
fantastic
No shipping.  Pickup near Pittsburgh PA, or maybe Baltimore MD.  It might fit across your back seat.
credit to Todd for the nice pics in his setup.  $750 (less than audiogon price)
Angaria
Re: "Quantum Destroyer" subwoofer - rythmik servo
« Reply #1 on: 3 Jul 2010, 04:41 pm »
going for less than construction costs...
will also trade for f4 or f5 clones, or interesting SETs
« Last Edit: 4 Jul 2010, 07:28 pm by Angaria »
Angaria
« Reply #2 on: 26 Jul 2010, 03:37 am »
weekend ^
I am willing to put pretty much any finish on this if you'd like.
Angaria
« Reply #3 on: 26 Aug 2010, 01:41 am »
still available - should say this was built to be the maximum internal volume for the sealed servo
« Last Edit: 26 Aug 2010, 03:25 am by Angaria »
