JPS Labs Wiring Discontinued?
0 Members and 1 Guest are viewing this topic. Read 1434 times.
Ron
« on: 19 Jun 2010, 11:51 am »
 Recently noticed that JPS Labs internal wiring is no longer being offered as an upgrade option for GR Research kits. Wondering why it was discontinued? Other than being a little bit on the expensive side, I thought it was an excellent product and well worth the extra cost.
« Last Edit: 19 Jun 2010, 09:38 pm by Ron »
Danny Richie
Re: JPS Labs Wiring Discontinued?
« Reply #1 on: 19 Jun 2010, 09:43 pm »
I had to buy a lot of it at a time $$$ and it was a slow seller. Plus our latest wire that we are using is fairly close in performance. Close enough for me to not want to buy more of the JPS Labs wire.
I have about 12 feet of it left.
Ron
« Reply #2 on: 20 Jun 2010, 11:19 pm »
 Thanks Danny for the reply. The JPS Labs wire is certainly a very high quality wire, but since it was such a slow seller and fairly expensive, I certainly understand why you will no longer be stocking it. I agree too that the standard solid core copper wire that you are now providing with all your kits is a close second to the premium JPS Labs wire.
