0 Members and 1 Guest are viewing this topic. Read 6175 times.
It would all make sense, if I was playing music. Low end feed back means the need for better isolation.But this happens w/ nothing playing, hell it happens w/ the TT motor off and the arm parked, which is what makes it such a mystery.
This problem seems a little more mysterious. From the loading thread: "Ok, since I've come back to vinyl, I've seen mention of 'load' matching. I'd never heard of this 30 years ago, when I had my first Thorens. My pre list an input impedance of 47kOhm, which is same as the Ortofon 2M Blue.I'm really leaning toward the Denon DL-160 as everyone says it has a huge soundstage but I've seen no specs on impedance. Anyone know? Does it matter that much?"The only way you're going to figure this out is troubleshoot. Surely other Rega owners have used this cartridge successfully. Do you own a multi-meter?Did you try the old cartridge? Please hook up the old one again. You're not going to get anywhere theorizing. 1 loose cartridge clip can do exactly what you described. If you need to tighten a clip, use something like a big pin inside the clip and gently squeeze the clip with your needlenose. The pin will ensure that you don't accidentally crush the clip. neo
I personally think rumble filters are good with vinyl and subs. Mine goes a bit wacky without it. I also think you should find out exactly what the issue is before you spend another dime.
