Shielding for tube phono preamp
0 Members and 1 Guest are viewing this topic. Read 3947 times.
JohnR
« on: 17 Jun 2010, 10:56 am »
I'm wondering if anyone could relate their experiences with shielding for a phono preamp. Has anyone built a tube phono pre in a "wood side with Al top" enclosure and then later moved it into an enclosed metal box?
sts9fan
Re: Shielding for tube phono preamp
« Reply #1 on: 17 Jun 2010, 12:09 pm »
As in sheilding the whole box?  When I built my Pearl I used shielded mic cable for all the connections.
JohnR
« Reply #2 on: 17 Jun 2010, 12:21 pm »
Hi - yes, I meant the box itself. Unsure as to how much shielding is actually needed in practice for this kind of circuit.
sts9fan
« Reply #3 on: 17 Jun 2010, 12:24 pm »
Is the power supply in the box?
JohnR
« Reply #4 on: 17 Jun 2010, 12:32 pm »
Ah, good point. Yes, that's the intent. I suppose I should worry more about that.
Wayner
« Reply #5 on: 17 Jun 2010, 04:22 pm »
Keep the power supply components on one side, preamp components on the other. Perhaps a steel plate between the 2 for some shielding. Steel, is a better shield then aluminum. Mu-metal is the best, but most expensive. Also insulate the input connectors from the metal.
Wayner  :D
Dan Banquer
« Reply #6 on: 23 Jun 2010, 12:14 pm »
Are engineering types and ex manufacturers allowed to comment in this thread?
d.b.
sts9fan
« Reply #7 on: 23 Jun 2010, 01:02 pm »
No need to ask
Dan Banquer
« Reply #8 on: 23 Jun 2010, 03:03 pm »
My first question is do you really need the case as a "shield"? If you live in an environment where you are close to transmitting antennas or you have other electronic gear giving off assorted interference then yes you do need a shielded case.
If that's not the issue then there may well be a safety grounding issue.
Can you volunteer any applicable information that might help to answer your question?
d.b.
Speedskater
  • Kevin
« Reply #9 on: 23 Jun 2010, 03:17 pm »
Dan, I think that everyday we see more and more sources of interference. Soon our refrigerators and water heaters will be communicating to the power company or your PC.  An unshielded system will suddenly have interference problems at the worst possible times. Your guest has a new cell-phone or your neighbor gets a wireless system or a new communications tower gets turned on.
Dan Banquer
« Reply #10 on: 23 Jun 2010, 03:20 pm »
I would generally agree if one lives in an urban or suburban area, but out in the country?????
I'll wait for more info on this one.
    d.b.
« Last Edit: 23 Jun 2010, 04:30 pm by Dan Banquer »
« Reply #11 on: 24 Jun 2010, 03:25 am »
Hi John,
Yes, I have been working on a phono stage (separate line preamplifier) with external power supply and shielded, metal chassis phono section. Frankly I would not go any other way.
Good luck with your project.
JohnR
« Reply #12 on: 24 Jun 2010, 07:57 am »
Hi Dan - thanks for responding. I guess that's the question I'm asking... I haven't built the preamp yet, just thinking ahead to chassis options for the next project after my line stage. I'm in a suburban environment but on the edge of the city; no transmitting towers close by and in fact I'm in a bit of a shadow for regular TV and cellphone transmission. I do have cordless phone and wireless networking in the house.
I'm thinking that perhaps I will go for an enclosed Al chassis (e.g. Transcendent Sound phono), as a reasonable medium between open chassis (e.g. Bottlehead) and Steve's fully-shielded choice. I may put the PSU in a separate chassis.
