Should I VariAc?
0 Members and 1 Guest are viewing this topic. Read 870 times.
boycephoto
Should I VariAc?
« on: 16 Jun 2010, 02:03 am »
I have a NOS NIB Dynaco Stereo 80, solid state amplifier.  It was a kit and consturcted by a lab tech about 38 years ago.  It has never been run since testing after construction.
Should I power it up using a VARIAC?
I think it is time to put it on the chopping block and I want to make sure it works properly.
Thanks for your help
Dave
Re: Should I VariAc?
« Reply #1 on: 16 Jun 2010, 02:18 am »
WOW  38 years is a lot of time, surely you will need use a VARIAC if you have one, and maybe more.  It is good start the Variac with 10V, and after afew hours rise slowly to 20V and so on.
I do not have a Variac and use various autoformers.
Capacitors in use last 10 to 20 years, so with 38 candles on this cake you may need extra care with this amp, Iam not informed about these procedures and I will let it to a amp expert, as there is various in this good site.
Good Luck,  Gustavo
