0 Members and 1 Guest are viewing this topic. Read 8668 times.
That is really my understanding of the problem. He chose to minimize the tracking error of the arc from the line, this ensures minimal distortion for the entirety of playback. I am assuming alternative alignments make different compromises or are better suited for a different arc curvature (different arm length). Is that correct?Tangential comment:I see tons of obscenely expensive hi-end convential pivot tonearms on the market and then wonder why. Why not just go linear-tracking tonearm? I can see the reason for convential pivot for economical tonearms, but why hi-end?
I have been reading up on the topic of alignments for all of 2 days. I had never seen the names Bearwald, Lofgren (except for Nils), or Denesen, et al until that other thread.However, my simplistic understanding of the problem is that vinyl is cut with a linear tracking like cutter, so the cutting head moves horizontally along a line. Most conventional tonearms pivot from a single point therefore the stylus follows an arc.The arc must approximate the line the best it can. The deviation of the arc from the line is called the tracking error. This is much like the opposite problem as calculus where a bunch of small lines approximates a curve. What Baerwald demonstrated was that for a given arc curvature that the tracking error could be minimized with a certain alignment with "null" points at a certain two points. This is really analytic geometry, a fairly classic calculus problem. That is really my understanding of the problem. He chose to minimize the tracking error of the arc from the line, this ensures minimal distortion for the entirety of playback. I am assuming alternative alignments make different compromises or are better suited for a different arc curvature (different arm length). Is that correct?Tangential comment:I see tons of obscenely expensive hi-end convential pivot tonearms on the market and then wonder why. Why not just go linear-tracking tonearm? I can see the reason for convential pivot for economical tonearms, but why hi-end?
The down side of a long arm is that arm mass tends to go way up and MOI (moment of inertia) gets degraded. neo
I believe Technics arms have two null points. Albeit, the second null is closer to the spindle that the other popular alignments.http://www.vinylengine.com/twisting-your-cartridge-headshell.shtml
Yes, it does, but it's in the label area and therefore, not a useful null point.
Thanks for listening to my first AC post.
IMO the best sounding arms tend to be between 9 1/4" and 10 1/2". This is long enough to reduce tracking angle error without the added mass, MOI of a longer (12") arm. Like most generalizations, this is not necessarily true.
