0 Members and 1 Guest are viewing this topic. Read 2796 times.
Pretty nice looking speaker. I wonder how the two sound compare to each other? My guess is the minimal baffle on the SS will help achieve better transparency, timbre, imaging, envelopment and ASW (apparent source width).
Better highs for sure, the RAAL is far superior to the LCY (and any other ribbon for that matter). Selah makes a speaker with Accuton and RAAL drivers, though it's a monitor.http://www.selahaudio.com/id237.html
I cringe when I see such definitive statements like this. How do you know this? Have you heard every other ribbon or even a comparison of the two tweeters in question? That is, each in a properly constructed cabinet for the particular tweeter? Also, the speaker being discussed has a midrange that goes up to 15kHz supposedly. How does that affect the response of the ribbon tweeter? That is, does the ribbon need to be great if the mid is so great? I don't think you can tell much about these speakers without a direct comparison where the two speakers are in the same room and amplified using the exact same equipment, interconnects, etc. (and you consider differences in efficiency). Pretty much anything else is complete speculation.
