Question for Mr Tanner..
0 Members and 1 Guest are viewing this topic. Read 1235 times.
colhogan
« on: 10 Jun 2010, 09:06 pm »
James:
 I was hoping to get some advice on  using the phono stage in my Bryston .5B Preamplifier to gain the best perfomance from it.
I'm using a Rega P-1 'table,& find my self wanting a bit more gain than my .5B offers,so I'm using a tube buffer between the 2 units.Although it boosts the phono signal, I'm finding there is a bit of hum when the volume is turned up past about 9:00.
Is there any way to cut back on this? My outlets are all 3-prong grounded.I tried the "cheater plug"
but no luck..
Any advice you can offer is greatly appreciated.
Patrick
  • The Demo is Everything!
    • http://www.bryston.com
Re: Question for Mr Tanner..
« Reply #1 on: 10 Jun 2010, 09:13 pm »
James:
but no luck..
Patrick
Hi Patrick - there is aways a balance between GAIN and NOISE but remember that our preamp is running full out Class A and you are attenuating the signal with the volume control on the preamp.  So do not let the fact that your running the volume control on the .5B at say 2-3 oclock.  That being said we could maybe increase the gain in the phono stage for you another 6dB if you want.
james
colhogan
« Reply #2 on: 10 Jun 2010, 09:38 pm »
Thanks for the advice, James.
 Another concern of mine is will the hum damage anything in the long term?
I meant to ask, does it make a big difference which Phono ctg is being used? I'm using a AT 95E,which is a pretty decent CTG for the price.. :icon_lol: ..
So I guess my question is will the gain increase if I use a "better" MM ctg?
Patrick
 P.S:
 I was able to pick up an Older 3B (1990). This thing is still going strong!
Sounds really good,and built like a small anvil! :icon_lol:
Patrick
« Reply #3 on: 11 Jun 2010, 12:28 am »
Patrick
 P.S:
Patrick
No harm can be done and a higher ouput cartridge will certainly give you more gain (volume)
james
