0 Members and 1 Guest are viewing this topic. Read 9604 times.
Awesome, Josh! How are you incorporating it into your system with the DEQX? Is the DEQX going to digitize its analog signal?-Jim
DOH!!!I go to try to set up my arm last night, pulled out the cartridge and the cantilever snapped off. Well not off-off, but dangling. $600 cart used very little. So, now to decide on whether it is worthwhile to have it fixed. Can it be fixed?
Why bother with a turntable at all if you are running it through a digital processor? All it does is sound like a good CD player at best then.I've used almost every major DSP based system out there. They all kill the analog magic. Get an SL-1200 and a budget cart and call it a day, it won't matter all that much.
