Preamp Suggesstions
0 Members and 1 Guest are viewing this topic. Read 3533 times.
LadyDog
Preamp Suggesstions
« on: 9 Jun 2010, 11:00 pm »
After numerous years living in the integrated amp world, I'm considering jumping back to a preamp/amp.  ?
Some general guidelines:
looking used, to get best bang for buck
budget $2,500
preference toward tubes
remote optional
not sure what amp I will end up with, but it will probably be solid state
speakers - have too many, Chesky C1, Selah Peridot, Verity Fidelio, just to name a few that may be used in the chain
So far my list entails;  Conrad 17, Cary 98sp, Joule 100,150, Blue Circle BC3, and First Sound
Since I have not kept up with things, any others out there I should add to the list?
Thanks in advance for your time.
Jeff
Will2
Re: Preamp Suggesstions
« Reply #1 on: 9 Jun 2010, 11:33 pm »
Jeff, if you're looking for tubes with some gain I have been impressed with what Bill at Response Audio offers.  I can't disagree with you when it comes to bang-for-the-buck with used items, but you can get close to that with some of his specials - check them out here http://www.bellaextreme.com/specials.htm
Big Red Machine
« Reply #2 on: 9 Jun 2010, 11:43 pm »
I've had more amps than preamps in the last 4 years but the best preamps in my system were the Response Bella, Dodd battery we auditioned for one day, and most recently I have been stricken with the BAT stuff (quiet, responsive to tube rolling, built like a tank).  All can be had easily undeer $2k.
revrob
« Reply #3 on: 9 Jun 2010, 11:48 pm »
I picked up a used Joule LA-150 MKII that had been upgraded from a LA-200 and it was the best $1,500 I have ever spent. I have it matched with Wyred4sound mono blocks and it is absolutely fabulous. You can't go wrong with Joule however I am sure there are other great deals out there for $2,500.
Best of luck.
roymail
  • Roy in TX
« Reply #4 on: 9 Jun 2010, 11:58 pm »
Take a look at Niteshade Audio, and contact Blair Lamphear.  He's very knowledgeable and will accomodate whatever you need.  Not to mention his stuff is top notch.
Larkston Zinaspic
« Reply #5 on: 10 Jun 2010, 01:14 am »
Scroll down to the model 11A, exactly at your price point:
http://www.sasaudiolabs.com/specials.htm
Could also scope out a Lamm LL2 Deluxe used... :scratch:
K Shep
« Reply #6 on: 10 Jun 2010, 01:28 am »
Aesthetix Calypso
In your budget, here is an add on Audiogon with photos, there is another classified asking less with out the pretty pictures.
http://www.audiogon.com/cgi-bin/cls.pl?preatube&1281144422&/Aesthetix-Calypso-remote-contr
  • Speakers....What Speakers ?
« Reply #7 on: 10 Jun 2010, 01:31 am »
A nice Modwright.....here...  :wink:
Eric
« Reply #8 on: 11 Jun 2010, 08:39 pm »
I would echo the 11A. I have one and love it
KnowTalent
  • ...stuck in the middle with you
« Reply #9 on: 21 Jun 2010, 07:16 pm »
Look for a used/demo Parasound JC 2
pure magic imo
