0 Members and 1 Guest are viewing this topic. Read 17910 times.
What planet are you from? I just got done proving that your statement is totally false and you still keep on. Do you not understand geometry?If rcag_ils gives me his spindle to tonearm distance that he wants to drill, I can give him the exact overhang to achieve any Baerward or Lofgren's null point locations. The 5 drawings I submitted above have 5 different spindle to arm spacings, yet all achieved the same null points.
If the op knows what arm that they wish to install, the manufactures information regarding the S-P distance is available. Cool, so we know what distance is required. Now what is the most accurate way to locate then distance so the drilling is on the exact spot?Any ideas? I would look at a metal gig that sits on the spindle with a small pilot hole at the manufacturers spec so an arc could be traced showing all suitable location for dropping the drill.
I see you added something to your post after I responded. What I said was correct. If someone wants to change their alignment from Loefgren A to Loefgren B, it will necessitate moving the cartridge further forward in the headshell and probably changing the angle slightly. This is assuming the pivot is in a fixed position. The overhang will also change. This is a known fact, according to the laws of geometry. The arc of a Loefgren A will be different from a B. Your statement about your CAD program is very misleading. The equivalent alignments you suggest, if it gives you nulls at 70,29 and 116.6 can either be achieved with a Loefgren B protractor, or it's not a true Loefgren B alignment. Overhang is often difficult to measure and is not necessary to achieve 2 nulls. If the cartridge, headshell slots, and eff length will not allow a particular alignment, then no "equivalent" alignment will be the same. The distortion figures that you think justify that choice will differ. I'm trying to help the OP get it going. If he misses the mark by a couple of mm, or can't measure overhang exactly, it's not a problem really. He can get a good alignment. You, on the other hand are trying to promote yourself, by offering something for free, that is inappropriate in this case. neo
