0 Members and 1 Guest are viewing this topic. Read 17905 times.
I'll be drilling the arm board, one for a Grace 707. one for a Linn basik +. I've found the spindle to pivot distance. Isn't it if the S to P distance is correct, then the null points have to be correct? The arc doesn't change with where the tonearm's mounted on the board, does it?
No problem, certainly all valid points; as you say (and as I alluded to with respect to Conrad's software) an arc protractor to be effective requires that the arm be mounted precisely at the manufacturer's recommended P to S distance. I do think that Wayne's comment/point regarding the relationship between overhang and offset is a valid one though, at least when using an arc protractor and using an alignment different from that specified by the tonearm manufacturer (and there have been many reports from users who have done so and felt they heard improvements). Change the alignment protocol (ie. from Stevenson to Baerwald) and hence the overhang (while still achieving an effective alignment) and the offset will change as well which is why the cartridge will not sit square in the headshell and be twisted or skewed. There seems to be an abundance of confusion on this particular aspect of alignment among many vinyl users. You can have a virtually perfect alignment without the cartridge being square in the headshell and that's because the offset changes to achieve alignment (along with all the other parameters-overhang, effective length etc.) at the different null points.If the overhang changes, the offset has to change as well.
As far as hole size - go with the manufacturers recommendations. Positioning of the mounting bolts in most arms determines mounting distance. With the Linn, you'll need 3 bolts on a 6 bolt pattern. The template is available in the VE library. Look under Linn - Ittock.
Overhang is useless unless you're mounted perfectly at manufacturers spec. neo
What planet are you from? I just got done proving that your statement is totally false and you still keep on. Do you not understand geometry?
If you have access to a machine shop it might be of use. I did a quick check to see what the manufactures distances were and had an armboard cut but instead of drilling a hole the size of the pillar mount, I had a larger circle cut. I then had a disc cut to that hole size, with a shallow lip on the top and it was threaded to the bottom so I could lock it to the armboard with a large nut. On that disc, I then had a hole drilled for the armtube pillar, but it was 4mm off center. Now the assemble and set-up.
