N3 build
0 Members and 1 Guest are viewing this topic. Read 6715 times.
Rclark
Re: N3 build
« Reply #20 on: 25 Jun 2010, 06:16 pm »
can you please describe your paint and finish?
also, aren't  the vents too large? i thought for the tl it tapers to a small opening.
they look great and i just might copy em.
mms3
Re: N3 build
« Reply #21 on: 25 Jun 2010, 06:33 pm »
Where will you be putting the GR emblem?
Um...I hadn't really thought about it.  I actually forgot about it until you mentioned it.  I guess that goes in the same category as grills.  I'll do it at some point, but right now its time to listen to music!
mms3
Re: N3 build
« Reply #22 on: 25 Jun 2010, 06:39 pm »
For the painted parts, I did 2 coats of sanding sealer, 2 coats of primer, and several coats of black enamel gloss(I'm not sure how many.  Just until it looked right.)  Then several coats of wipe-on poly.  For the veneer, I left it natural, and used several coats of wipe-on poly.
The ports are per the plans, with the difference being that they're on the front: http://www.gr-research.com/pdf/Neo3box.pdf.  Also, I did a 3/8 roundover on the outer edge of the port, so that may be making it look larger than it is.  I checked with Danny before doing so, and he said it wouldn't affect SQ.
Rclark
Re: N3 build
« Reply #23 on: 26 Jun 2010, 07:28 am »
With the products you used, how durable do you feel is the finish? Also, how did you apply the paint?
mms3
Re: N3 build
« Reply #24 on: 27 Jun 2010, 03:03 am »
Durability should be fine.  Polyurethane seems to be a common protective coating for speakers.  I brushed the sealer/primer, and sprayed the paint.
