XLR's-RCA's
0 Members and 1 Guest are viewing this topic. Read 1218 times.
drummermitchell
XLR's-RCA's
« on: 7 Jun 2010, 02:59 pm »
I'm sure I read it before,BUT can you use the bal and rca at the same time on the Bryston amps.
The two components(prepro-Rca+26 bal)to amps,not to be used at same time.
As I have a bitchin time to swap cables,it would sure make things easier being able to use both,
                                          STREEEESSSSSSS.
servingko
Re: XLR's-RCA's
« Reply #1 on: 8 Jun 2010, 03:04 pm »
Yes,  I had this confirmed by James a couple of years ago.  Both can be used at the same time.
drummermitchell
Re: XLR's-RCA's
« Reply #2 on: 8 Jun 2010, 05:59 pm »
Yes,I thought that,thanks,I emailed James and confirmed it.
I talked to Mike this morning and I don't have to go that route.
reason is,my AV-8 was giving me ground loop hum thru the 26,so I have been using the av-8 to the 28s for music,movies.
Now(I'm gonna take off the ground pin)of the Av-8's pc(the cheap one)and see what happens.
If that don't work,it's only a 6 buck cord,then i'll do the XLR's+rca's.
I think I have too much gear...NOT :thumb:..
