0 Members and 1 Guest are viewing this topic. Read 9414 times.
- it is a very short path for the signal so any reflections will bounce back & forth between transport & DAC & eventually die out before the important transition stage at the DAC. This last point may be wrong & I'll have to check it out again but it is a cheap experiment before going off to buy expensive digital cables.
only partially wrong Yes, it will bounce back & forth.No, it will not die before next transition window.
Jay did you hear the stock hiface before the mod? The reason I ask is I'm not impressed at all with my stock Hiface. I have all the parts to do the mod but thinking if I mod it I won't be able to sell it, kind of in a catch 22 right now.thanks
ContextA few months ago I wanted to upgrade my Wadia6 based system. For about 18 years, the Wadia6 has served me well. My system before the hiface consisted of the Wadia6 driving a benchmark Dac-1, through an AES/EBU interface cabled with an old Audio Research litzlink XLR cable, which is all I had lying around. The Benchmark drove Fostex PM-2 active speakers directly. Simple system.I had been considering the new Logitech touch, but stumbled into the hiface as I was reading through the latest posts on the audio boards. The concept of the hiface seemed to be compellingly simple, a USB device that allowed a PC/laptop to output a S/PDIF signal via a USB port, which was reclocked by the device to have very low jitter. John had developed this even further by supplying the best possible power supply to the quartz oscillators. He also could supply a USB cable that allowed you to connect your own 5V supply. Enjoy the Music and 6Moons reviewed the stock unit favourably. I promptly sent off an order to John for the hiface boxed mod, as well as the USB cable.That was two months ago. I knew nothing about PC based systems. My use of Windows had been confined to ripping a few CDs using WMP from my own library to my work laptop, for listening at the office, and nothing more.The modded hifaceWhen I got the unit from John, I had to read up and install Foobar on my work laptop. This laptop I use crunches spreadsheets out during the day, its nothing special, just a middle of the range Latitude notebook which work supplied me.At this point I did not even have a digital cable, so off I went to the local electronics shop to get a BNC terminated digital cable, cost me $10. Nothing fancy. Just whatever they had.First impressions of the laptop reading WMP ripped CDs, using the KS driver and Foobar then hiface mod, then cheapo digital cable to benchmark was unexciting. Music did not sound as good as the Wadia6 driving the benchmark. Using WMP via a DS driver was better but still not as good as the Wadia6 as transport.I sat down and tried to optimise the set up I had. Changed a few settings on Windows and foobar, and finally I downloaded EAC. This time I used EAC to rip my CDs. Lo and behold, now I had the sound that surpassed my previous set up.Using foobar to play WMP ripped discs is a sonic wasteland. Don’t bother. WMP playing WMP ripped discs was better. Using foobar to play EAC ripped discs and playing that through hiface has been the real deal, in my limited experience. My comments below refer to the hiface in comparison to the Wadia6/Benchmark set up:1. Latitude E5500 laptop running Windows XP2. Foobar playing 3. EAC ripped tracks4. via John’s modified USB cable (with my 4 x 1.2V(nominal) rechargeable batteries as power supply)5. To john Kenny modified hiface (battery powered boxed version)6. No name BNC digital cable7. To Benchmark Dac-18. Then through PSC silver XLR cables9. To Fostex PM-2 active speakersSound has1. Massive improvement in low level detail; much greater transparency2. Significant improvements in subtle timing information3. Just better across the whole frequency spectrum4. Better separation of everything; better imaging5. Much greater information of the recording space coming through on playback6. Thunderous, growling bass. Bass just has that density it did not have before. The change had me checking my speakers to see if I had not inadvertently boosted the bottom end.7. A more relaxed and natural presentation all around, one that opens up the recording venue for you to hear.I have listened to John Williams “A Portrait of John Williams” since 1982. I first had the LP, then the CD. On Cavatina, the subtle rhythm of the guitar accompanying the melody came through clearly for the first time in all those years of listening. On Sakura, for example, there is a sense of a guitar playing within a space to a much more noticeable extent than my previous set up.With the Wadia6/Benchmark, I thought I had it good, but this is just so much better in every way. Listening to the modded hiface, one just has to think a lot less and relax and let the musicians wash over you with their playing. You can hear their playing so much more. You can hear the space where they are playing so much more.I don’t know about expensive analogue, because I haven’t been exposed to it that much, but for me the modded hiface, the modded USB cable, is almost too good for words. It’s knee-tremblingly good. I woke up this morning thinking about whether I should listen to ABC Classic FM, or my other CDs. I downloaded high res samples, so this lets me listen to high res too. Fabulous price, fabulous sound, for peanuts in the scheme of things, with enough technology to see me through the next 10 years. All on a journeyman’s laptop, with no esoteric settings let alone tweaks.I didn’t know John from Adam but I took a punt. His work is DIY – you won’t get something as well finished as an iphone. But I have found him to be a gentleman. The stock hiface is a product with a brilliant concept and execution, and John’s mods and cable takes this up to a stellar maxed out level, which is critical to us anal retentive audiophools.Before I embarked on this journey, I just wanted something that was at least as good as my previous Wadia6 as a transport. The modded hiface has exceeded that objective magnificently for me, in my set up, and for my tastes and hearing faculties.Google hiface modifications to look it up
