Tripath Amp and WiFi: Interference?
0 Members and 1 Guest are viewing this topic. Read 1320 times.
tw_switzerland
  • I like the 3D imaging of a good stereo chain.
« on: 6 Jun 2010, 10:02 am »
Since I have a Class-T amp (TA 10.2), the Squeezebox mutes from time to time for some seconds and rebuffers. I think that the near Tripath chip seems to interfere with the WLAN/WiFi reception.
Has anybody else suffered from such an effect?
Is there something I can do in order to reduce transmission of the T-amp? (connect metal case to ground?)
Thomas
sts9fan
Re: Tripath Amp and WiFi: Interference?
« Reply #1 on: 6 Jun 2010, 08:50 pm »
I have used the same amp with no issue. How do you know it is the amp?
tw_switzerland
« Reply #2 on: 7 Jun 2010, 03:20 am »
Well, I'm not 100% sure, but the problems started when I added the TA to my chain a few weeks ago. And the Squeezebox seems to stream without any problem when I switch the TA off.
I read reports that there may occur interference of TA with FM radio reception within 5 meters or so. And maybe that wifi band is affected too.
But to make it clear: I'm not 100% sure. But there seems to be some evidence.  :scratch:
