FS Bellari VP129 Tube Phono Preamp
0 Members and 1 Guest are viewing this topic. Read 1069 times.
Mathew_M
« on: 5 Jun 2010, 09:25 pm »
Hello,
The only catch with this Bellari is that the mute switch is broken and is stuck in the "mute" mode.  This may be an easy fix for someone with a little know how.  With that said, the headphone jack sounds excellent and is not affected by the Mute switch.  So if you're looking for tubed phono amp for headphone use then this is it.  I'm including a 1/4" to RCA plug so that it can be used with a normal pre or amp.  The cool thing about the Bellari is that it has a built in volume pot so that you can use it directly to an amp and avoid the preamp completely.  I'm asking a flat $75 for it.  Price is firm at this point. Price includes shipping within the continental US and no PayPal fees.
Thank you,
Mathew
etcarroll
Re: FS Bellari VP129 Tube Phono Preamp
« Reply #1 on: 5 Jun 2010, 10:57 pm »
How exactly did the mute get hosed?
What make of tube does it have?
Mathew_M
« Reply #2 on: 6 Jun 2010, 02:48 am »
I assume that the button just broke.  Not from abuse as I rarely used the Bellari.  The button itself still clicks up and down.  The tube is the stock EH.
TrungT
« Reply #3 on: 6 Jun 2010, 02:55 am »
Mathew
Check your PM?  :wink:
