Function of ground pin on external plastic power supplies
0 Members and 1 Guest are viewing this topic. Read 828 times.
tw_switzerland
  • I like the 3D imaging of a good stereo chain.
Hello
I have a question I did not find an answer for:
What is the function of the third ground pin on the external switching power supplies? E.g. like the ones used for most Tripath amps.
I saw that there are power supplies having two pin connectors only, and others (most) do have 3-pin-connector with earth/ground.
As the case is plastic, it doesn't have to be connected to ground. And the amp itself is not connected to the earth pin at all. So I think one reason for ground could be filtering out the noise? Or am I totaly wrong? :scratch:
And are the ones without ground as goog as the others?
Thomas  :-D
Speedskater
  • Kevin
Re: Function of ground pin on external plastic power supplies
« Reply #1 on: 5 Jun 2010, 12:33 pm »
The one's with two pin connectors have to pass further safety tests by an authorized agency (UL/CSA in N. America). So making a good case that will pass the test may cost more than the 3 pin plug.
