0 Members and 1 Guest are viewing this topic. Read 9762 times.
There are quite a few things in your list to digest all at once, so I will group them into separate posts. Anyone is welcome to join in. It is a fair observation to say every manufacturer believes their equipment is the best. The philosophy behind all of Niteshade Audio's products: Develop the best possible design around a component's strengths using as streamlined a circuit as possible. That means we use electronic devices in accordance to the best circuit position available to them. Using a component properly yields superior performance and naturally lends itself towards superior circuits. What I consider inferior design properties:1] When more components are used than are necessary to achieve good performance, relative to a streamlined circuits that can outperform it or at least perform as well. 2] Forcing a component to perform a duty it is not designed to perform. The result is an inferior circuit that, for example, could wear out tubes quickly.The above philosophy has a bearing on my answers to some of your questions. You forgot a category of tube technology: OTLPower tube wiring configurations configurations:The best is what is called a tetrode hookup. Triode and ultra-linear are technically inferior because they have to stress the tube in order to achieve high performance. The stress comes from higher idle current. As a result, the tube will produce less power per input watt. This issue should be avoided at all costs. Triode and ultra-linear hookups also reduce power supply filtering effectiveness. That is not good either. Dual rectifiers: Permit double the current output of a single rectifier. We go by application to determine if this is best for your requirements since sonic attributes are modified going from single to double. Parallel tubes: Reduce output impedance and increase output power capabilities in amps and preamps. The increased power output manifests itself as a stabler circuit during sustained high power demand as well as transient response performance. Wide bandwidth performance is also increased greatly. Single ended output: One tube is used for the output stage per channel. Advantages include a reduction of components, less heat output and economical tube replacement. This configuration can be made light weight without a severe compromise in performance. Push-Pull: Think of it as a children's see-saw. This is split-load amplification. One tube handles the negative part of an incoming wave while the other amplifies the positive. This is the most efficient way to design a high powered amplifier. When made properly, they are as clean and exact as single-ended amps. Another advantage to push-pull: They have natural noise canceling abilities unlike single ended amps. OTL: Transformerless output: Multiple tubes or transistors are configured in a push-pull design that utilizes a bi-polar power supply that, when everything is balanced, eliminates DC current at the output. Like every other design, they have sonic attributes that people like. It is my opinion that OTL should be strictly in the realm of transistors. A circlotron implementation of the OTL philosophy is best implemented with tubes: An output transformer is used, however, there is little or NO DC current flowing through the transformer's primary leading to excellent performance AND a reduced parts count relative to an OTL circuit. I will write more later on. Others are always welcome to jump in!
Ummm Guy, please learn how to cleanly respond to postings. Your responses to Blair gave me a headache trying to determine who was saying what.Anyway, I don't agree with everything Blair said, here are my opinions:Triode vs Tetrode / Pentode - This depends on whay you want to hear. Apples to apples Pentodes and Tetrodes typically give you more power. As always, there are exceptions. In my experience triodes sound "purer", with less grain and more of what Sam Tellig used to refer to as palpable presence. BTW - if you like the sound of 300Bs, you should also listen to 2A3s or 45s, each one is more linear and extended than the typical 300B.SE vs Parallel vs PP - There are times when be best circuit is the simplest circuit. Again, SE is as simple as you can get. Now the trick is, with only one output tube, you limit power and potentially bandwidth. With parallel circuits you can increase power, but you have the potential for tube mis-match. The audibility of this may be questionable (some people hear it, some don't.) PP brings in the issue of phase splitters (which BTW don't have to be active devices, you can also use a transformer) and their issues.OTL - Ralph Karsten has been making OTL amps for over 20 years. They are reliable and rugged and sonically damned good. The technology is sound (no pun intended.) What Blair wrote makes little sense - Atma-sphere amps are cyclotron amps and DO NOT have an output transformer; they also use triodes. They aren't push pull, so I don't know where Blair gets his comments from. BTW - you might want to investigate OTL, either Transcendent ot Atma-sphere, there are many member here that love what OTL does, and in fact, so does the press.
I am trying to learn how to cleanly respond to postings
The preview button helps alot.
" (drop the quote marks ", I just put them in to stop the interpretation of the bracketed command). At the end of the quoted section just throw in another "
Guy,Try this:Press the quote button to respond to a post. In the response window you will see some code as a header to the quote - "". You can use this to bracket anything you want to be a quote, so that if you want to interject a comment inside of a quote you just go to the line where you want to comment and insert a "". The viewer will recognize the bracket as a command and will box and grey out the quoted material. You can then add your comment on the next line." Lets see if it works ? Yes, it does work ! "When you are ready to quote more material, either copy and past the initial quote command (1st line of the post) or just type in "".If this looks confusing, don't worry - it's easier to do than to explain it
