FET Valve Ultra 350
0 Members and 1 Guest are viewing this topic. Read 2810 times.
willpower45
FET Valve Ultra 350
« on: 3 Jun 2010, 11:50 pm »
If used well within the capabilities of the standard Ultra 350 (medium sized room, easy to drive 91dB speakers), would the double die option improve the sound?
avahifi
    • http://www.avahifi.com
Re: FET Valve Ultra 350
« Reply #1 on: 4 Jun 2010, 07:18 pm »
With 91 dB efficient speakers, I would not expect the Double Die option to be of any great extra value to you.
However, if you are ordering the amp new, the option cost ($264) could be of real value if you ever switched to low impedance, low efficiency speakers or if you wanted to run a couple sets of speakers or more at the same time.
Best regards,
Frank Van Alstine
Wayner
« Reply #2 on: 4 Jun 2010, 08:16 pm »
Isn't a 3db increase in speaker efficiency like doubling amplifier power? If so, going down 3db, would cut the apparent power in half (88bd).
Wayner
ricmon
« Reply #3 on: 5 Jun 2010, 01:02 am »
While using my previous Ultra 550 with 90dB speakers I burn one too many tweeters.  I wish that the "double" option was available as I ended up moving to a different manufacture.  I really like the sound I was getting from my AVA setup but if you want to get the best out of your speakers I suggest the "double" upgrade.
good luck
Brett Buck
« Reply #4 on: 5 Jun 2010, 03:56 pm »
    Could you elaborate a little more?  Why does running a conventional amp blow up tweeters, and why does  having a "double die" fix it?
    Brett
Tone Depth
  • Music Lover
    • SRLPE Wheel Works
« Reply #5 on: 5 Jun 2010, 06:07 pm »
Recommended for very difficult loads and for those that want to play unreasonably LOUDhttp://avahifi.com/index.php?option=com_content&view=article&id=129&74a0ad6b5f7a1df0ef4ab98b8fffbb41=5c588f8df6023ba297579046a0dbce23
I remember reading about Ricmon being one of those in the second category.  8)
    Brett
Wayner
« Reply #6 on: 5 Jun 2010, 06:11 pm »
Speakers generally get blown up with insufficient power. What happens is that the power supply and output transistors start to clip and deliver a chopped off sine wave, that chopped sine wave is now pulsating DC. DC to a speaker is bad because it "freezes" the speaker, time wise, and does nothing but create heat. Heat melts the voice coil wire and silence is the outcome. That is why I always like an amp that has as much power as I can afford.
Besides, ricmon likes to listen to his music LOUD!!!!!!!! :eyebrows:
Wayner  :D
