0 Members and 1 Guest are viewing this topic. Read 3502 times.
I am in the market for a plunge router. I am gonna be cutting holes for speakers. What bits am I going to want to cut the holes and do the recess lip? I got the Jasper jig now I just need to figure out how to use the thing. Kris
I would recommend going to Sears (or even sears.com) as they always have specials on plunge routers. All my routers are from Sears and they have been used almost on a daily basis for a couple years now and still running perfect. You can also check woodcraft.com as they often have very nice routers on special. I would look at a good 1/4" straight bit for cutting out the holes. Anything larger will take more material than needed and take longer as well. The smaller the bit, the faster the cutting.
Suffice it to say, I still love the router. The LED task light is beyond orgasm.Bob
I guess you will be cutting through thick MDF? This is the best you can get:http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=1619EVSNap.
I have a woodcraft down the street from me. It's dangerous. I guess I need to see whAt routers the Jasper jig attaches too.
Generally, for handheld use, you'd want something much smaller & easier to control!Don
If you're only using it to cut holes for speakers, go cheap, even used. MDF is easy to route, but be sure to wear a mask and eye protection.
By cheap do you mean under $200 or under $100. Here are some I was looking athttp://www.amazon.com/Hitachi-KM12VC-4-Horsepower-Variable-Collets/dp/B0002ZZWX8/ref=sr_1_5?ie=UTF8&s=hi&qid=1275657841&sr=1-5http://www.amazon.com/Bosch-1617EVSPK-4-Horsepower-Variable-Collets/dp/B00005RHPD/ref=sr_1_1?ie=UTF8&s=hi&qid=1275657841&sr=1-1Honestly I have no idea what the differences are in the $100-$300 rande. I think I want something not too big.
