0 Members and 1 Guest are viewing this topic. Read 5045 times.
Seriously, if you try to read it carefully, you should be able to understand or at least get an idea of what that is. Those are common wording, you shouldnt need a dictionary.
Seriously, if you try to read it carefully, you should be able to understand or at least get an idea of what that is. Those are common wording, you shouldn't need a dictionary.
If you look at this description of the Sierra-1 crossover:http://www.ascendacoustics.com/pages/products/speakers/SRM1/srm1tech.htmlIt says:"OPPIX stands for Optimized Paradromic Phase Integrated X-Over (crossover). This sophisticated variable slope crossover precisely aligns the acoustic phase response of multiple transducers at the exact point where the response of one transducer crosses over to another, with reference to a specific point in space. This precise alignment allows the transducers to mimic a single point source radiator, allowing for symmetrical dispersion even with an asymmetrical transducer layout while maintaining a linear frequency response and greatly reducing off-axis phase and response anomalies. It also avoids the undesirable frequency response anomalies commonly found with even the best coaxial drivers."
It is to my ardent aspiration to circumvent his oratorical proclivities and to make feasible his indulgences in such frolicsome proclamatory recreation. However, the magnitude of his phraseology is too copious for my diminutive comprehension. Parsimony, dude.
