What speaker spike for B&W floorstanders?
0 Members and 1 Guest are viewing this topic. Read 14717 times.
Deftone
« on: 3 Jun 2010, 04:30 am »
Just want to know what speaker spikes do you guys used for floorstanders?Is the SBN7 and SBN9 ok or the one from sound anchors?
Ryanz
Re: What speaker spike for B&W floorstanders?
« Reply #1 on: 3 Jun 2010, 04:32 am »
Did your speakers not come with any?
Deftone
« Reply #2 on: 3 Jun 2010, 04:49 am »
Sure,it does,but i just don`t like the look and its a bit tiny
Ryanz
« Reply #3 on: 4 Jun 2010, 03:50 pm »
Deftone,
I would imagine a fair amount of work goes into testing speaker spikes. And in my opinion stick with the factory ones, but it's your dime. And I guess as long as they fit and you like the way they look, get the ones you're refering to. After all they are just spikes. My opinion though.
Berto
« Reply #4 on: 4 Jun 2010, 03:56 pm »
I just go new speaks and currently using stock spikes, but my friend who has same ones, told me he he heard a nice step up with the herbies threaded gliders. You just have to know what size to buy. They give a 90day trial period, so not much to lose if you dont like, plus they protect the floor and look like they allow you to move w/o lifting the speaks..  I have no afilliation with them, just a friends advice who has been at this hobby for about as long as i'm alive.
Frisco
« Reply #5 on: 4 Jun 2010, 04:51 pm »
Check these guys out.......
http://www.soundocity.com/Gallery.html
vegasdave
« Reply #6 on: 4 Jun 2010, 06:46 pm »
The question is, why does B&W supply such cheap and cheezy spikes with their speakers? It's not like their speakers are cheap in price!
Napalm
« Reply #7 on: 4 Jun 2010, 07:34 pm »
Bolt them down and forget about it.....
Nap.   :eyebrows:
Ryanz
« Reply #8 on: 4 Jun 2010, 07:41 pm »
Nap.   :eyebrows:
With a 22 caliber concrete round, and call it good. With a big enough room you could play table tennis by yourself!  :thumb:
vegasdave
« Reply #9 on: 4 Jun 2010, 08:52 pm »
hmm?
StigO
« Reply #10 on: 5 Jun 2010, 07:49 am »
http://www.soundcare.no/
Try Norwegian ones....
vinyl_guy
« Reply #11 on: 5 Jun 2010, 12:49 pm »
Expensive, but well worth the $$$ http://www.starsoundtechnologies.com/SinglePlatforms.HTML
or for less $$$ http://www.starsoundtechnologies.com/THREADED.HTML
Both provide an audible improvement over the spikes B&W provide. If you can afford it, go with the Sistrum stand
timind
  • permanent vacation
« Reply #12 on: 5 Jun 2010, 01:39 pm »
The Soundocity outriggers are excellent, especially if you need a bit more stability.
As a bonus they will steal your pics and post them in their gallery if they like them. Here's my pic in their gallery.
 Should I get a royalty?
Phil A
« Reply #13 on: 5 Jun 2010, 02:50 pm »
That's true.  I have old P6s as mains in the secondary basement system and while I don't use the system tons, their spikes are not the greatest and don't even fully penetrate the carpet and padding over the concrete basement floor.  I don't use the spikes for my Rel subs I have in the main system (they are sitting on ceramic tiles) and I might drag them out and see if they fit. From memory, they looked much nicer than the B&W ones.
vegasdave
« Reply #14 on: 5 Jun 2010, 11:10 pm »
Good idea.
Deftone
« Reply #15 on: 6 Jun 2010, 12:57 pm »
Frisco, thats the stand that i am trying to get from soundcity,the SBN9 for the front of the speaker and the SB7 for the rear mount.By the way i have the 803.Is the stand from sound anchor any good?Anyone?
electricbear
« Reply #16 on: 6 Jun 2010, 03:04 pm »
I have used Sound Anchors with great success on 804s, 803s and 802s. I recommend them to my clients who buy B&Ws even though we are not a dealer
vegasdave
« Reply #17 on: 6 Jun 2010, 10:26 pm »
I've heard good things about Sound Anchors for years. I've never seen them in person or tried them, though.
