Acoustic Foam vs. Compressed Fiberglass
0 Members and 1 Guest are viewing this topic. Read 19550 times.
SDFish
« on: 2 Jun 2010, 09:43 pm »
Has anyone compared acoustic foam to compressed fiberglass for use as room treatments?  If so, how did they compare?
Big Red Machine
Re: Acoustic Foam vs. Compressed Fiberglass
« Reply #1 on: 2 Jun 2010, 09:53 pm »
acoustic foam is very limited in the frequencies it can attenuate.  There are tables somewhere to show you the comparisons.  Much better off with 703 or 705 if you are serious.
bpape
    • Sensible Sound Solutions
« Reply #2 on: 2 Jun 2010, 09:56 pm »
Even 'good' acoustic foam is far inferior to compressed fiberglass, mineral wool, or acoustic cotton.  Most foam products of comparable thickness will be considerably less effective as effective below 500-1kHz depending on thickness - which is where most rooms require additional control.
Just a comparison - coefficients at 125, 250, 500, 1k, 2k, 4k
2" Auralex foam
0.11 0.30 0.91 1.05 0.99 1.00
2" OC703
0.17 0.86 1.14 1.07 1.02 0.98
2" 3lb density acoustic cotton
0.35 0.94 1.32 1.22 1.06 1.03
Note the differences from 500Hz down (1st 3 figures for each product)
As you get thicker, the differences are even more pronounced.
Bryan
low.pfile
« Reply #3 on: 2 Jun 2010, 10:45 pm »
Bryan
So the higher number means more attenuation of that frequency?
(maybe the wrong term)
Is a higher coefficient better?
bpape
« Reply #4 on: 2 Jun 2010, 10:52 pm »
All else equal - yes - higher numbers mean more absorption at that center frequency.
Also, when you consider the price of OC703 vs the price of the 2" Auralex, the 703 is performing better for less money.  The cotton is a bit more but the performance is outstanding.
Bryan
low.pfile
« Reply #5 on: 2 Jun 2010, 11:24 pm »
Thanks for the info Bryan!
drphoto
« Reply #6 on: 5 Jun 2010, 04:35 am »
It's sort of crazy what people charge for that foam stuff. You can't beat GIK for the performance/price/quality of build.....and fast turn around for custom colors. I could have maybe saved a few absolute dollars if I'd gone DIY, but I value my time too.
And I think the panels look a lot nicer than a bunch of Sonex too.
mfsoa
« Reply #7 on: 5 Jun 2010, 03:58 pm »
...and don't forget GIKs outstanding customer service and advice. They don't openly treat their audiophile customers as delusional sheep like some acoustical treatment companies.  :nono:
I have also bought from bpape directly (Green Glue - thanks Bryan!) with the same top-notch service and low prices.
Two thumbs up!   :thumb: :thumb:
-Mike
Ethan Winer
  • Audio expert
« Reply #8 on: 9 Jun 2010, 04:24 pm »
I'm not one to usually defend foam. :lol:
Good foam (ie: Auralex, not Foam By Mail and Foam Factory etc) absorbs similarly to rigid fiberglass of the same thickness. The reason most foam seems to spec worse is because it's not usually made as a solid slab. For example, 2-inch thick foam is two inches thick only at the points or peaks, depending on how it's sculpted. If you took two pieces of sculpted foam and nested them face to face, then the foam really would be two inches thick throughout. And then it would absorb about the same as rigid fiberglass.
That said, it's not our fault that foam companies choose to cut out half of the material to make a pretty pattern! :duh:
--Ethan
bpape
« Reply #9 on: 9 Jun 2010, 04:37 pm »
-Mike
You gotta remember I'm a delusional audiophile too!   :thumb:
Bryan
bpape
« Reply #10 on: 9 Jun 2010, 04:38 pm »
--Ethan
Agreed.  But then, take double the price of Auralex foam to get that face to face performance and compare to the other products.  Makes some of the other options even more desirable IMO.
Bryan
Ethan Winer
  • Audio expert
« Reply #11 on: 10 Jun 2010, 05:30 pm »
We need to talk about that some day. :beer:
Exactly. :lol:
--Ethan
SDFish
« Reply #12 on: 13 Jun 2010, 01:11 pm »
I see that fiberglass is better at bass absorption.  But if used to absorb reflections (i.e. not trying to absorb bass), how does the sound of the two materials compare.
bpape
« Reply #13 on: 13 Jun 2010, 01:17 pm »
It depends on what reflections you're talking about.  Even side wall reflections would be nice to get down into the vocal range (200ish Hz for deep male voice).
Rear wall reflections can be more critical in lower frequencies to prevent cancellations with direct waves from the front.
Bryan
