**SOLD** Kimber 4PR 23' speaker cables
0 Members and 1 Guest are viewing this topic. Read 1960 times.
Big Red Machine
« on: 1 Jun 2010, 07:54 pm »
Pics later.
I have two pair of Kimber 4PR speaker cables that are in the 23/24 foot long range.  I used them in a bi-wire set up.  I bought Mark's reality set this weekend so i don't need these.
$75 per pair or $140 for both sets.  All terminated ends.
Kimber Kable 4PR Features
    * Four brown and four black braided conductors
    * 2 x 14awg/2.08mm
    * High-purity copper
    * Special formula PE dielectric
Kimber Kable 4PR Technical Specifications
    * Parallel capacitance: 312pF @ 20kHz
    * Series inductance: 0.654H @ 20kHz
    * DC loop resistance: 0.041Ù
    * Total reactance: 0.0825Ù @ 20kHz
    * Frequency response: 0.5dB - 100kHz
Connector Options
    * Bare wire
    * SPD standard 1/4" spades
    * SBAN standard 4mm banana plugs
    * PostMaster PM25 standard 1/4" spades
    * PostMaster PM33 oversized 5/16" spades
Cable Range Details
    * Full Range: one run of cable per channel, two connectors at both the amp and speaker ends
    * External Bi-wire: two runs of cable per channel, two connectors at the amp and, four at the speaker end
« Last Edit: 18 Jun 2010, 07:51 pm by Big Red Machine »
Big Red Machine
Re: Kimber 4PR 23' speaker cables - 2 pair
« Reply #1 on: 1 Jun 2010, 11:40 pm »
I have two mirror image sets for sale:  One set has spades both ends and the other has spades one end and bananas on the other end.  This allows bi-wiring very easily as you can attach the spades under the amp lug and then push in the banana and then connect each set of spades at the speaker end.
Big Red Machine
« Reply #2 on: 7 Jun 2010, 12:30 pm »
Two pairs available
Big Red Machine
« Reply #3 on: 11 Jun 2010, 09:44 pm »
The banana ended pair just sold on Ebay.  Spade to spade set left - 23 feet each run.
