0 Members and 1 Guest are viewing this topic. Read 7912 times.
Taking this one step farther (and admittedly to the absurd), could "Sound by Salk" be a promotional tool for public accommodations?
Taking this one step farther (and admittedly to the absurd), could "Sound by Salk" be a promotional tool for public accommodations? Never mind...just thinking out loud...- Jim
Unless it's a very small place, in order to get sound to the opposite side from where the speakers are, you're going to have to turn up the volume to get over the normal din. This means that the people nearest the speakers are going to be blasted out, which means that they'll raise their voices to be overheard, which means that you'll have to increase the speaker volume to get the sound on the side opposite the speakers loud enough. It's a vicious circle. I'd recommend in ceiling or cheap speakers spread throughout the place, played at low volumes.
...One other point. Margin wise, I am not sure speakers is where a new coffee shop should spend its money. There is a lot of competition out there in NYC. Most people are not coming to a coffee shop for sound. I would spend the money on what brings people to the place, including a good "stage" setup if there will be an open mic, good coffee, etc. and not worry too much about the main sound (so long as it is serviceable).
If you really want to differentiate yourself,do your own roasting...
