Two subs or not two subs? That is the question.
0 Members and 1 Guest are viewing this topic. Read 1427 times.
Ryanz
« on: 31 May 2010, 03:26 am »
Hello all,
I have the chance to pick up another Paradigm Ultracube 10" subwoofer for $500, half the price of what I payed for my first one. I already have one in my system now. My question is, is there a significant benefit to having two subwoofers?
Ryan
cujobob
Re: Two subs or not two subs? That is the question.
« Reply #1 on: 31 May 2010, 03:42 am »
Two subs are better than one, but there are better subs than that for $500 I'd guess.  Mixing and matching subs is not a problem if you do it correctly (use the subs within their optimum ranges) and locate the subs apart from each other to get better in-room response.
drummermitchell
« Reply #2 on: 31 May 2010, 04:23 am »
You could audition another one to see what you think or hear.
I use to use one and then I tried two,I'd never go back to one.
I find with one if you even move a foot out of your sweetspot,the bottomend will change quite a bit.
Two subs will even out the bottom,she sounds so much more complete,just a nice foundation for the rest of the MUSIC.I think you will be quite surprised,I was :thumb:.
Ryanz
« Reply #3 on: 31 May 2010, 04:31 am »
Yeah. I have a small living room, so unfortunately my placement options are less then ideal. I think two might even it out a bit. I know the Ultracubes aren't the best subs around but they're compact and fit my needs perfectly. I just wasn't sure if there would be an issue with having two subs.
Drwellbe
« Reply #4 on: 9 Jul 2010, 12:49 am »
You should place one sub next to your mains and the other sub on your side wall middle point in the room
rockadanny
« Reply #5 on: 9 Jul 2010, 02:02 pm »
Great suggestion for starting locations of two subs. This is how my configuration ended up and it works for me.  :thumb:
max190
« Reply #6 on: 9 Jul 2010, 03:03 pm »
Hello all,
Ryan
YES!
What worked the best for me was stacking them secured together by double-back tape.
