0 Members and 1 Guest are viewing this topic. Read 9272 times.
MikeYes, you download through the B&W download app, usually it have several choice of format, 16-bit or 24-bit FLAC and 16-bit ALCAfter you down load the file, you can do anything with the file as you like.I think new member can download all the old albums (35)
When I signed up, I was able to download all of their catalog for the price of the 2 titles/ mo for 1 year fee.Not all are high-rez (> 16/44) -Mike
Marius, Your link doesn't work...but the ones above do. My take on this is the trial gives you one song to two albums per month, the subscription gives you two albums per month, at a sample rate of your choice (highest being 24/48). The real issue is that the darn catalog is only available once you commit (as far as I can see). Edit: Thanks Mike. Great to know you can download them all.Boston Symphony orchestra has a very nice subscription. For $30 you get 3 month access to a dozen 24/88 albums and many more redbook ones (plus some multichannel). Of course it won't take 3 months to download 12 hirez albums, but the point is that if you like them all it's less than $3/album for 24/88k.http://www.bso.org/bso/shop/audioDetailDMSubscription.jsp?pid=prod3230013&area=
All six of the Gergiev pieces I have from the SoS (including La Mer and the Mahler 7) are 24/48. I general, all of the "big" conductors that make up 80+% of the classical side of the SoS catalog are available in 24/48, like all of the Gergiev, Sir Colin Davis and Haitink .
