0 Members and 1 Guest are viewing this topic. Read 8317 times.
I would really take a look at this http://www.gikacoustics.com/gik_elite_pillar.htmlMaybe Bryan will chime in here as well.
Well, a resonator would likely do the trick too if properly tuned and placed in the room without the need for instrusion into the music reproduction chain. Not like I have a dog in the fight since we don't build Helmholz resonators. I just offered the xover option since the OP said he really didn't want to go with a treatment to try to solve the problem.Bryan
TJHUB - What speakers are you using?
How about simply stuffing up your TL ports on the Salks with socks Any other electrical solution would probably affect the sound quality.
You can either use a passive, speaker level xover or you can look into an active high pass only xover if you want to continue to use the xover on your sub for that portion.Check out Marchand. If you can DIY, they have the board and frequency module for $46. Just supply connectors, power supply, and case. http://www.marchandelec.com/xm1.htmlFor something more complete, you can check this one out. http://www.marchandelec.com/xm44.html The one you'd actually want is the XM44-1AA I believe. Can be either high pass or low pass and you pick the frequency. A bit more though at $800.Bryan
What sub?And does it have speaker level inputs/outputs?
I used to have a preamp with analog bass management that allowed me to integrate my subwoofer for music and home theater. I really liked the flexibility and it all worked very well. However, about 7 months ago, I changed to a preamp that does not have analog bass management. Now I’m looking for a solution.My new preamp has dual volume controlled outputs. I am currently running my sub for music by using its internal low-pass filter and parametric EQ. This works PERFECTLY. The problem is that I also run full-range speakers that have a rather large bass peak at 36Hz created by my room. There is no way for me to deal with this other than using my EQ’d sub. What I need is a way to high-pass filter my main speakers at 60-80Hz with a steep slope to keep them out of that 36Hz region as much as possible.Are there any good solutions out there that won’t hurt sound quality at all and don’t cost thousands of dollars? I’m looking for ideas that possibly aren't digital to avoid that A/D-D/A conversion.Thanks.
Soryy for being off topic but what preamp did u use? Im looking for a bass management preamp, can u advise? thanks
SVS PB13-Ultra. So yes it does just about everything, but I refuse to run IC's out to thing and back. I also use my sub for both music and HT, so I don't have the spare inputs I'd need to run the LFE directly from my receiver to the sub. That's just not the direction I want to go.
What it does not have is just what you need...a high-pass filter.That would have solved your problem.What you need is a way to cut off your main speakers above the problem frequency.You need something like the Bryston 10b xover.
