NEW to the headphone thing and would LOVE some help.
0 Members and 1 Guest are viewing this topic. Read 1513 times.
TKonrad.NOLA
I do most of my listening via laptop.  Is there a headphone amp that I can connect via USB or is there another way to connect a headphone amp to my Macbook Pro?
I was considering purchasing the AKG-K701 as that is what lead me to get a headphone system
eclein
Re: NEW to the headphone thing and would LOVE some help.
« Reply #1 on: 27 May 2010, 08:14 pm »
DigitalDude there are a bunch of amps-USB DAC's-etc..you might want to check out:
http://www.head-fi.org/
The DAC I chose, Grant Fidelity Tube DAC-09 does USB, Headphone etc..as does Maverick D1 and others, here are a couple links:
http://www.grantfidelity.com/site/Grant_Fidelity_Tube_DAC-09
http://www.mavaudio.com/base/
the above two are basically identical, FWIW-Cheers..Ed L. :thumb:
saisunil
« Reply #2 on: 27 May 2010, 08:28 pm »
I have recabled 701 as one of my reference amps. From a purist perspective:
Have a
1. Separate source
2. Separate headphone amp
3. Recabled 701
Depending on your budget - you could get a USB Dac plugged into a separate headphone amp or a usb dac/head-amp combo - headphone.com has very good selections.
701 need to be
1. recabled
2. have powerful / high current amp to really shine ... hybrid amps can add some tube warmth / coloration / tube-rolling fun/flexibility.
3. Burn-in for at least 300 hours ...
Of course you can pick and choose what you want to do / afford - I am just sharing my experience ...
Have fun!
tjohnusa
« Reply #3 on: 5 Jun 2010, 12:04 am »
If you want to keep cost down look for a Totalbithead it's a usb dac/amp
